New plug and play ECU available soon!
Old Sep 29, 2015 | 12:17 AM
  #261
3XCstore AP1's Avatar
Originally Posted by skinsfn36
Originally Posted by 3XCstore AP1' timestamp='1443491359' post='23760477
So you are trying to sell a product that hasn't even been tested yet. Since February of this year when you started advertising, you never tried to at least get a hold of an s2k owner to at least try your product? Is the s2ki community your guinea pigs? Maybe you should rethink your game plan reverant.
I think it's been tested and is running on a local to him car (Greece), but nothing in the US/Canada.
Wish someone reputable here in America can get a hold of this ecu and do some real extensive testing. Just saying...Maybe a reputable shop
Old Sep 29, 2015 | 04:45 AM
  #262
skinsfn36's Avatar
Originally Posted by Reverant
The local test car already received a free unit. I've been doing these ECUs for more than 5 years for Miatas, so trust me when I say that there's slim chance of sending a unit out without testing it. This car was dynotuned and raced in 35°C/95°F.The dyno sheets and datalog where posted for everyone to examine.
I also said I can offer a discount for the first reviewer.
What would I tell a tuner when they ask me what ECU I'm using?
Old Sep 29, 2015 | 04:47 AM
  #263
skinsfn36's Avatar
Ideally for Reverant, he needs to send a unit to someone like Jeff Evans or VitViper. Someone with a lot of tuning experience.
  #264
Reverant's Avatar
Former Sponsor
Enhanced MS3 by MS Labs. Based on Megasquirt Technology.
Old Sep 29, 2015 | 04:52 AM
  #265
skinsfn36's Avatar
So when looking for a tuner, we would search for people with Megasquirt experience?
Old Sep 29, 2015 | 04:54 AM
  #266
Reverant's Avatar
Former Sponsor
Preferably yes. Evans has tuned at least one of my Miata ECUs, so he certainly has the knowledge needed.
Old Sep 29, 2015 | 05:53 AM
  #267
snitm's Avatar
Originally Posted by snitm
So do you have pictures of the finished product in a protective case? Does it still need to be zip-tied in place or have you developed a more polished install?
Did you keep the ethernet port (as such it won't fit in a standard s2k ECU case)? If so how is the ethernet port useful to end users?
Please speak to installation constraints (can it still be placed where the original ECU is?).
And again, pictures of the final enclosed ECU would be appreciated.
Old Sep 29, 2015 | 06:00 AM
  #268
Reverant's Avatar
Former Sponsor
The ECU was not designed to fit in the stock case; I did think about doing a simpler board-only version that will fit in the stock enclosure and be ST-class compatible but that will be a different product.
I'll post pictures of the ECU in the enclosure later in the day.
Old Sep 29, 2015 | 06:11 AM
  #269
skinsfn36's Avatar
What is the best method for monitoring outputs live? (I.e. oil temp, oil pressure, MAP, AFR, water temp)
My plan was to buy AEM Infinity and use a Serial to Bluetooth output and monitor everything on an iPad mounted to the dash.
Old Sep 29, 2015 | 06:16 AM
  #270
Reverant's Avatar
Former Sponsor
You can use any OBD-II gauge that is programmable, such as the scangauge, or use a Bluetooth to serial and use ShadowDash or msDroid. I prefer the OBD-II method as it still allows you to have a laptop connected for tuning/logging at the same time.
