New plug and play ECU available soon!
Old Jan 20, 2016 | 06:25 AM
  #311
kordo_90's Avatar
Hallo, I am the guy with the laguna blue s2k which appear in the video above,
I am writing this post to share my experience with Enhanced MS3 ECU.
I am generally very pleased with the result obtained and would highly recommend it to anyone going to change oem ecu.
Especially the ecu was the last modification made ​​on my car so I can evaluate without being confused by something else .
my car is used mainly as a track car and weekend car.
for the install the only requirment was a wideband sensor . after installing the car run without any problem or something weird and were clearly faster without even tuning .
so I drive on the dyno where I did the fine tuning. the changes were small and perhaps was not necessary.
the dyno wrote 250hp with a freeflow exhaust and a custom intake with very good diagramm on torque.
So the next weekend i take the car to the track and the result was a track record for NA cars,
the car was a lot better compared to the performance of it the weekend before in imola(Italy)
here can see the best lap there to compare with te lap above
https://www.youtube.com/watch?v=k-8lqa62Sf4
I am not the best man to describe the features of the ecu but my favorite is the obdii capability so i can use my tablet to
monitor the engine and the car.
Anyone can pm me for extra info or add me on fb (vaggelis kordogiannis)
Old Jan 20, 2016 | 04:24 PM
  #312
steelers743's Avatar
250hp with intake exhaust only on a stock NA motor? That seems a little high. If you have a Laguna Blue I am guessing it is 06+ DBW. Whats the the advantages or functionality of this over flashpro?
Old Jan 20, 2016 | 10:44 PM
  #313
Reverant's Avatar
Former Sponsor
Not whp, it's crank hp. This is a european AP2, meaning it's still the non-DBW/VSA version.
Old Jan 20, 2016 | 11:09 PM
  #314
kordo_90's Avatar
It is 04 and has been resprayed so flash pro wasn't an option. I have not opinion on flash pro but I think that with MS you can have the advantages of a standalone ECU without losing the functions which offer a flash pro.
Old Jan 20, 2016 | 11:25 PM
  #315
michaelnyden's Avatar
Not sure if this has been answered already but can this purge the evap canister unlike the aem?
Old Jan 20, 2016 | 11:27 PM
  #316
Reverant's Avatar
Former Sponsor
Not on the current iteration of boards. If this is an important feature for at least a couple of S2K owners, it can be added.
Old Jan 21, 2016 | 03:18 AM
  #317
flanders's Avatar
I think AEM does support evap purge, at least the V2.
You should ad it if possible Reverant, personally I'm leaning more to kpro now but I still got an interest in this MS ecu.
Old Jan 21, 2016 | 04:46 AM
  #318
iDomN8U's Avatar
You can't really compare Flashpro (Injector timing based tuning) vs VE (Volumetric Efficiency).
http://forums.haltech.com/viewtopic.php?t=5463
Please read up on the advantages of VE, it's the evolutionary step forward for tuning.
Old Jan 21, 2016 | 08:01 PM
  #319
dstevens's Avatar
Honda has used VE tuning since the late 80s, including the S2000.
Old Jan 22, 2016 | 05:24 AM
  #320
iDomN8U's Avatar
My apologies I could have sworn it was Alpha-N based. However looks like you can switch between that.
So then it comes down to features and CPU speed/memory
