oil life%?
Old Dec 11, 2012 | 04:24 PM
s2kang's Avatar
Default oil life%?
think this is probably a simple question but anyone know what this lamp sign indicates?
[media]http://www.facebook.com/photo.php?fbid=10152391620225495&set=a.10152376297 335495.961379.525125494&type=1&relevant_count=1&re f=nf[/media]
i recently purchased my 06 from a CarMax. had the battery and brake fluid replaced then this came on. what's the A and the 1 for? don't think it's the engine oil, that's pretty clean.
thanks.
Old Dec 11, 2012 | 04:26 PM
g.guess88's Avatar
Pics not working. It would help a lot with a working pic
Old Dec 11, 2012 | 04:33 PM
s2kang's Avatar
does the link work? i just tested it out and seemed to. still figuring out these sites. thanks.
Old Dec 11, 2012 | 06:31 PM
g.guess88's Avatar
if you have clean engine oil, just go ahead reset the oil%, the mechanic probably didnt do that after the oil change
Old Dec 11, 2012 | 11:17 PM
s2kang's Avatar
oic, that makes sense. so it's just a engine oil monitor? how many miles are oil changes recommended at? 3k?
Old Dec 12, 2012 | 06:23 AM
g.guess88's Avatar
I believe factory is set to 3k. Yep it's just a monitor for engine oil
Old Dec 12, 2012 | 06:59 AM
FISH22's Avatar
Factory recommended changes are way above 3k. I think under normal use, it's about 7500 miles. The oil minder system goes off of ECU inputs, it's not just mileage. It will calculate throttle inputs, load, revs, etc. Pretty much, the harder you drive the car, the quicker the % will drop. On my 06 I always changed the oil when it got to about 20%. Which varied over it's life. Sometimes I got to 20% in about 4k miles, sometimes it would take 6k miles. All depends on how you drive.
Old Dec 12, 2012 | 08:07 AM
g.guess88's Avatar
Learned something new !
Old Dec 12, 2012 | 12:05 PM
s2kang's Avatar
wow, that's very interesting. thanks for the wealth of info. now i just gotta figure out how long it's been since the last change...
snowball
Mar 21, 2004 05:24 AM
navybeaN
Jul 15, 2003 08:04 PM
demonderrick
Jul 16, 2001 08:47 PM
Goldtrom
Apr 8, 2001 05:49 PM
BB AP1
Nov 28, 2000 01:14 AM
