Is it possible?
Old Sep 29, 2012 | 03:33 PM
lotus7racer's Avatar
Default Is it possible?
To lose the configuration of the AEM EMS?
All of a sudden my car will not start --- like to start but no go.
Has sparks on all cylinders -- good compression -- new TPS - New crank sensor - New cam sensor.
Noid test light for the injectors showing there is a connection.
When you turn the ignition, it will show 60 psi of fuel.
Do you think possible to lose the configuration or the mapping?
Old Sep 29, 2012 | 06:48 PM
jh4db536's Avatar
Is this a cold start issue? Hot start is fine?
Did you tune yesterday and find out this morning that the car barely starts?
Sent from my T-Mobile G2 using Tapatalk 2
Old Sep 30, 2012 | 03:41 AM
I was tuned before. It will crank, engine like to start but no go.
Does not matter if hot or cold.....will not start at all.
S2KVee
Sep 26, 2014 07:08 AM
s2kseven
Nov 4, 2013 04:07 AM
freshs2k
Nov 5, 2009 10:34 AM
03silver2000
Feb 9, 2009 03:43 PM
Venomous S
Dec 29, 2005 02:34 PM
