psi by speed or gear?
Old Jan 13, 2010 | 08:27 AM
Sarek's Avatar
Default psi by speed or gear?
My current setup had a speed dependent boost tune. it worked ok for traction if starting from a stop. But didn't work well for highway rolls because I was not in full boost until after 60mph (end of 2nd gear speed)
I assume that having psi based on a specific gear would better suit me. Is this possible?
I have the AEM 1052U EMS.
thanks in advance for any info
Old Jan 13, 2010 | 09:38 AM
wadzii's Avatar
Banned
boost by speed is pretty much for racing.
unfortunately the aem ems can not do boost by gear.
Old Jan 13, 2010 | 10:34 AM
jari8378's Avatar
^^ ^^yup
Old Jan 13, 2010 | 12:59 PM
Gernby's Avatar
Former Sponsor
Boost by speed sounds like it would only be valuable for drag racing only. I wouldn't expect it to work well on a road course.
Old Jan 13, 2010 | 01:00 PM
Gernby's Avatar
Former Sponsor
BTW, I would be surprised if the '02 tranny has a gear selection sensor.
Old Jan 13, 2010 | 02:45 PM
wadzii's Avatar
Banned
actually, it works very well!
Old Jan 13, 2010 | 02:58 PM
Sarek's Avatar
Thanks for the quick reply! I see, I guess I can always wire a switch between the 2 tunes. More specifically with and without the speed based
Old Jan 13, 2010 | 05:54 PM
wadzii's Avatar
Banned
thats pretty much how i usually set it up.
first we use a wg spring thats good for daily driving.
then we use 2 switches. one turns the boost control soleniod on and off. Turn it off, you have wg pressure. turn it on and the ems can control the boost.
the 2nd switch selects either boost by speed or a higher set boost level.
example, switch one off, is 10psi on the wg spring, switch 1 on with switch 2 off is 15psi, turn switch 2 on and you have boost by speed.
Old Jan 13, 2010 | 07:41 PM
Sarek's Avatar
that's a great and simple idea! same thing I was thinking and just add another switch to the solenoid, kinda like a master switch.
I have to change my wastegate spring. even at 10lbs (creeps to 12lbs) it still spins a little at the top of the tq curve in 1st and 2nd, maybe some R compounds first . Thanks again for your suggestion!
since on the subject, is it true that you don't want to go higher psi than double the WG spring rate? if yes, why not?
I'm thinking of possibly running an 8lb WG (for better traction) with the 2 switches but run up to ~20lbs max. Is this unwise?
Old Jan 14, 2010 | 05:25 AM
wadzii's Avatar
Banned
as far as the max boost on the wg spring, there is no telling.. some setups work good and some dont, you just have to see.
I dont see a problem running 20psi on an 8psi spring.
That Guy 1987
May 22, 2014 10:42 AM
admans2k
Sep 8, 2013 05:08 PM
p0staboy
Jan 21, 2011 08:53 PM
s2kdan05ems
Aug 21, 2010 10:50 AM
