Questions for Haltech PNP owners
Hi Guys,
Just got the S back from a the Tune and its not quite what I had hoped, I have been investigating a few issues and just wanted to ask a couple of questions.
Firstly, I just wanted to know if anybody changed their resolution from Haltechs 500Rpm fuel, 400Rpm Ign and 20Kp load, to try and use as many of the 32x32 points and if so what did you decide to go with?
Secondly, Am I correct in assuming the base map and table are for non Vtec and the "Base (ACF On)" map and table are for Vtec? if this is correct has any body adjusted the resolution to suit (eg high resolution 0-6000RPM for base and then higher resolution 5-10000 for ACF on)?
and Lastly, Can you please confirm the setting used to raise and lower the vtec engagement point?
Thanks for any answers or clarification to anything I have wrong above.
Aug 23, 2013 11:46 AM
Purple Haze
Jun 9, 2004 02:01 PM
