Recent start up issues, with Haltech 1000
So I have a little update, so far it seems that if I wait for the tach to cycle through after turned the key, aprox 10 seconds before I press the start button she starts up right after a few cranks and does not need help from the gas pedal. Has worked the past couple of days. I'll keep an eye on it and get my batt. Tested this week.
DFWs2k, I knew it was doing something just didn't know what. You know it makes some sense though, before when I'd just start her up quick the car felt like it was flooded with fuel. So maybe this is the little trick. Crossin fingers this just keeps working. Dales my batt is pretty new too, but it's good to rule it out.
It takes time for bigger injectors (even with the proper cranking settings) after fuel pump has been primed enough to get the car started. I look at a modded car starting up with 8 or less cranks to be normal. Anything beyond that has to do with not enough cranking fuel, fuel pressure, fuel pump, injector settings in the ems, etc...
