Software Dyno for FlashPro users (and maybe KPro)
Old Jul 2, 2011 | 09:50 AM
  #81
itjunior's Avatar
First, thanks for your time and work. Very nice program!
Second, sorry for my bad english (from Brazil).
gernby, i have Hondata FlashPro and Honda Civic Si 2007.
I try use your program, but i have error. Can you do this program work with a datalog of FP and Civic Si?
I upload one datalog:
DatalogCivicSi-Excel Format
DatalogCivicSi-HondataFP Format
Can you help me?
Thanks for all.
Old Jul 5, 2011 | 05:28 AM
  #82
Gernby's Avatar
Former Sponsor
I was able to load the datalog in the Soft Dyno after adding a relative humidity to the end of the filename (id. Calibration_R4-001 40%.csv). Did you use the "Batch" button, or the individual "Open" button?
Old Jul 5, 2011 | 08:57 AM
  #83
Kyushin's Avatar
Banned
Very nice!!
Im sure every single CHP has this memorized and all the places I like to do it!
Old Jul 6, 2011 | 04:05 PM
  #84
itjunior's Avatar
Hi,
I try both, but doesn´t work for me.
I´m using Hondata FlashPro v.1.1.8.5 and Office 2010. Windows 7 32 bits.
With "batch button" i see this error:
With "open button" i see this:
Thx.
Old Jul 7, 2011 | 01:10 PM
  #85
Gernby's Avatar
Former Sponsor
After looking at your CSV file, it's clear that the issue is due to your language settings in Windows. If you change your decimal symbol from a comma to a period, it should fix the issue.
Control Panel -> Regional and Language Options -> Retional Options -> Customize -> Numbers -> Decimal Symbol
Old Jul 8, 2011 | 06:56 AM
  #86
itjunior's Avatar
Wow, work now!
thx!!!
Old Aug 2, 2011 | 03:44 PM
  #87
08s2000CRbackinblack's Avatar
wow, i just stumbled across this and cant wait to give it a try. sounds a little difficult to get it to work. i just need to change my map to "mbar" and put a "XX%" ex: 80% at the end of the datalog file name i usually use the date when saving a datalog, so 8-2-2011-80% would be a fine name to save the datalog under before exporting it to your program???. 80% for the humidity because i live in florida and then it should be able to open in your software??? my laptop is at home so i will upload the program tomorrow and try to upload a previous datalog to see what happens. anything else that i am missing. im getting a header on friday so i would like to figure this out before then to get a before and after with the header. super excited i found this just cant wait to get it figured out to work!!!!
Old Aug 3, 2011 | 05:23 AM
  #88
Gernby's Avatar
Former Sponsor
I think that's it. If you have any issues, please report back. Once you have everything set up correctly, it's super easy and quick. The only tricky thing left is finding the right location for repeatable WOT pulls that doesn't attract cops.
Old Nov 3, 2011 | 06:59 AM
  #89
Gernby's Avatar
Former Sponsor
I'm putting together an all new soft dyno using a totally different strategy. I'll post more about it later, but the "teaser" is that it works in real time while you drive, and it has much better resolution! I also believe it will work while in "Live Tuning" mode, but I haven't actually tested that.
Old Nov 5, 2011 | 02:17 PM
  #90
Gernby's Avatar
Former Sponsor
WHOOP! I just verified that the new soft dyno does NOT interfere with Live Tuning!!! I just did 4 pulls in the same driving cycle, and made 2 different ignition timing adjustments in the midrange (purple and blue lines). This will make street tuning so much faster and easier!!!
