Supercharge AFR suggestions
Old Mar 16, 2011 | 09:55 AM
s2konroids's Avatar
IMO/IME >12.4 in WOT is too lean.
Old Mar 16, 2011 | 01:10 PM
azride1983's Avatar
Are you talking about the corrected a/f?..coz if most people are saying the stock sensor is more accurate then i guess i'm running a bit rich. In the 10's-11's..i should see around 11.5-11.9 ratio wot. I guess i gotta get a wideband sensor to be sure....
Old Mar 17, 2011 | 09:41 AM
s2konroids's Avatar
I am talking about a using a wideband, i would not consider anything else as accurate.
My CTSC+AC @7psi runs at 12.5 low down until vtec at 4krpm then ~12.2 in vtec tapered down to 12.0 at redline
Old Mar 19, 2011 | 08:00 AM
Dan1987's Avatar
Hey,
Here is that datalog.
At the point the cursor is at my wideband was reading 12.2:1
So it gives you some idea of the difference between the readings.
Dan.
s2kparlay
Sep 22, 2011 06:04 AM
Booztin
Sep 13, 2010 02:28 PM
Dan1987
Aug 30, 2010 05:28 PM
roarings2k02
May 11, 2008 02:42 PM
Salaska
Feb 15, 2004 02:33 AM
