The time has come
Engine management topics, map and advice.
The time has come
Dec 16, 2015 | 07:01 PM
geekyjerry
Nov 2013
The time has come
I finally got my motor built. (9.1 compression/sleeved) .
What calibration can i run to start the car? Will get tune after break in.
THANK YOU FOLKS
geekyjerry
Find More Posts by geekyjerry
Dec 16, 2015 | 08:37 PM
steelers743
May 2010
I would talk to a tuner and ask if he can make you base to run with untill you get the full tune later.
steelers743
Find More Posts by steelers743
Dec 17, 2015 | 11:20 PM
geekyjerry
Nov 2013
Good advice. I have heard about running the same map as before. Same set up im running, just lower compression.
geekyjerry
Dec 26, 2015 | 05:54 AM
timg
Mar 2004
Decatur, GA
The factory tune will run a low compression motor. It's not ideal, but isn't a bad starting point.
Tim
timg
Visit timg's homepage!
Find More Posts by timg
Dec 27, 2015 | 03:40 PM
JUSTINTHECOASTIE
Oct 2008
St.Petersburg/Tampa, FL
The basemap hondata provides is a great start
JUSTINTHECOASTIE
Find More Posts by JUSTINTHECOASTIE
Jan 4, 2016 | 11:50 AM
tehlonz
Jun 2013
Albany ,NY
As said already . Use the stock calibrations , just be sure to choose the correct calibration for your ecu build (PRA/PRB).
tehlonz
Find More Posts by tehlonz
Lower compression motor questions
rickii
01:08 AM
Compression Recommendation
TrueSpaniard1
11:33 AM
new stroked motor idles then dies
prolux
05:54 PM
Is resleeving a must?
beroznikmal
05:59 PM
Back to Subforum
View Next Unread
Kpro2 to --> Kpro 4 & w/ RSX wideband
12:47 PM
