The time has come
Old Dec 16, 2015 | 07:01 PM
geekyjerry's Avatar
Default The time has come
I finally got my motor built. (9.1 compression/sleeved) .
What calibration can i run to start the car? Will get tune after break in.
THANK YOU FOLKS
Old Dec 16, 2015 | 08:37 PM
steelers743's Avatar
I would talk to a tuner and ask if he can make you base to run with untill you get the full tune later.
Old Dec 17, 2015 | 11:20 PM
geekyjerry's Avatar
Good advice. I have heard about running the same map as before. Same set up im running, just lower compression.
Old Dec 26, 2015 | 05:54 AM
timg's Avatar
The factory tune will run a low compression motor. It's not ideal, but isn't a bad starting point.
Tim
Old Dec 27, 2015 | 03:40 PM
JUSTINTHECOASTIE's Avatar
The basemap hondata provides is a great start
Old Jan 4, 2016 | 11:50 AM
tehlonz's Avatar
As said already . Use the stock calibrations , just be sure to choose the correct calibration for your ecu build (PRA/PRB).
rickii
Jul 17, 2017 01:08 AM
TrueSpaniard1
Jun 16, 2014 11:33 AM
prolux
Sep 4, 2009 05:54 PM
beroznikmal
Mar 27, 2004 05:59 PM
