Using the RSX wideband with the Kpro
Originally Posted by Hondata,May 18 2010, 10:28 AM
simplicity, ease of use, support burden
Maybe I'm missing something.. but my Kpro is installed in my Ap1
w. everything done..So $2k+ later.. & I still cant do anything, but load a base map because I need a wideband..
I heard good things about this site for o2 sensors. www.oxygensensors.com free shipping and the rsx wideband is around 150ish.
ECU pins can be found here for much much cheaper
http://www.newark.com/tyco-electronics-amp...211?Ntt=85C1211
Just to double check the pinouts. Does my image show the numbering scheme you're using in yellow? I only ask because the pins on the actual connector hardware that came with my kpro are numbered backwards (blue numbers on the pic).
I guess it has to be because numbered backwards 6 & 7 are taken. Of course I only notice this after going to the trouble of photoshopping that up.
Yeah, it must be. That's the direction the other A, B and C sockets are listed in the Helm manual. Probably just that manufacturer or type of socket that lists them the other way. Just freaked out a little when I thought it didn't line up.
Oh, related, the pins freezingcoffee suggested are a better fit for this particular connector. I picked up a bunch of both just in case.
Trying to track down the part number for the RSX O2 connector now so I can skip the extra weatherpack step.
Did you guys remove the stock primary o2 sensor, because right now I'm running the rsx wideband and the stock primary. I have the J's racing header, so I'm running the wideband in the wideband bung and the stock in the stock location, if that makes sense.
Originally Posted by JustinC,Jun 12 2010, 07:21 AM
Good luck. I couldn't find it.
The hardest part was getting the part number, but even then nowhere wants to sell these things in sub 5000 lots. Until I found Eastern Beaver Co. these guys have a paypal account and will ship single units or even just the spare pins and seals.
It's a Sumitomo HW Series sealed female connector. P/N F(6189-0132)
http://www.easternbeaver.com/Main/Elec__Pr.../SMHW/smhw.html
