Using the RSX wideband with the Kpro
Originally Posted by 96-EJ6,Apr 28 2010, 08:29 PM
One of these days I will get around to installing my testpipe and testing the RSX sensor side-by-side with our Autronic wideband.
When tuning I noticed just a slight difference in the readings, anywhere from 0.4 AFR richer from the RSX sensor to a perfect match. Please bear in mind that during my last tuning session the Autronic wideband was just in a tailpipe sniffer behind the catalytic converter, and the RSX sensor was in the factory primary O2 sensor location so this may have effected the readings. More to come, eventually...
Originally Posted by JustinC,Apr 28 2010, 08:09 PM
I had the RSX sensor in 1 bung and the PLX wideband in another bung on my header and they read within .1 of each other.
Originally Posted by spectacle,Apr 30 2010, 10:12 AM
But at what values? I would imagine anything in the 14's and 15's would probably be close...but when you go rich or lean that's where the discrepency would lie since the RSX o2 doesn't have the same resolution.
Originally Posted by spectacle,Apr 30 2010, 01:44 PM
The RSX read down to 10:1? How lean does it read?
I think the RSX can read somewhere in the high 10s low 11s...I think
So, let me understand, if I use the standard narrowband S2000 sensor, I have to leave the KPro in open loop all the time?
Also, would my tuner be able to switch from a PRA to PRB settings without any trouble?
If you switch from a PRA to PRB it will have to be retuned and you will have to have the before mentioned mods in order to run a RSX wideband.
