VAFC Harness Help
Old Jun 14, 2012 | 02:12 PM
s20009k's Avatar
Default VAFC Harness Help
Hi, i have a PnP harness from frog (i think) one of my pin broke from the block and i was wondering where can i find a replace pin for it.
Thanks
Old Jun 14, 2012 | 04:04 PM
Hawkeye_AP1's Avatar
Any pics of it? Replacement terminals, seals, and connector bodies are available for many different connector makes and types. I'm not familiar with this harness to know what type/make of connector it is. The unfortunate part is that if you have to replace a terminal, a lot of manufacturers have special crimping tools needed for crimping the replacement pin properly. Also, there can be special tools recommended to disengage the locking pins on the terminal so you can pull it from of the connector body without damaging it. It all just depends on the type of connector.
Can you do it without the tools, possibly, depending on the connector type. I am fortunate enough to have access to many of the required terminal extractors and crimping tools so I haven't ever really tried to do it without.
Old Jun 25, 2012 | 01:25 PM
s20009k's Avatar
BUMPPP with pictures. i need the small pin.
Old Jun 25, 2012 | 03:41 PM
JUSTINTHECOASTIE's Avatar
Send it back
s20009k
Feb 7, 2012 11:49 AM
24s2k7
Jan 29, 2007 02:42 PM
Slows2k
Dec 23, 2005 12:00 AM
Ro_Ja Boy
Feb 6, 2004 12:09 PM
S2KSuzuka
Oct 23, 2003 02:35 AM
