VAFC2 not reading 100% throttle
Old Dec 27, 2009 | 05:18 PM
sproket13's Avatar
Default VAFC2 not reading 100% throttle
When i floor it, it only reads 97.5% throttle. I tried to manually move the throttle plate, same results.
What does that mean? My sensor is off center? Should i loosen it, go full throttle, and tilt it till the VAFC reads 100%? Does ours even have play? Never messed with it...Any help appreciated!
Old Mar 1, 2010 | 06:23 PM
pwrofdrm's Avatar
Well I certainly wouldn't adjust your throttle position sensor based off the reading on your VAFC-II. I'm not sure why you even installed one.
If you're concerned your throttle position sensor needs calibration look up how to read the voltage off it...it's very easy to do.
Old Mar 3, 2010 | 10:35 AM
Gernby's Avatar
Former Sponsor
It is a bit strange that it would not read 100%, but I don't think there is any reason to be concerned about it. It won't have any negative impact on the functionality of the VAFC, and won't change how you tune it.
Old Mar 3, 2010 | 11:25 AM
s2konroids's Avatar
You havent set it up right, when you first set it up you must have your foot flat to the floor for 10secs then leave off for 10secs, cant remember the name of the screen.
I had the same problem.
MugenR
Jul 28, 2012 06:37 AM
sproket13
Dec 28, 2009 11:01 AM
s2fast725
May 19, 2004 04:53 PM
bunjimobile
Jan 24, 2004 10:28 AM
