When accelarating and decelerating
Old Jun 7, 2011 | 10:31 PM
H22toF20's Avatar
Originally Posted by spo001
Originally Posted by H22toF20' timestamp='1307428870' post='20656265
"Tip in", is an enrichment for fast throttle input. The bigger the TB you run, the more air that is allowed in per TPS %. So if you put a big TB on and mash it to the floor, you'll actually run lean for a second until you mess with the "tip in"
Hi Guys
Many thanks for the information
So the Tip in is the TPS SCALE right ?? as mine is setted at minimum 1% and max 104% . And I M RUNNING A STOCK TB.
Shall i change it to default ??
Thanks
Nicky
No. The TPS scale just makes sure the EMS know's what percent the throttle is open. "Tip in" is something else entirely.
For instance, if you're at idle, then mash the gas to the floor very fast, the instant surge of air will overcome the ideal pulse width for the load/RPM you're at. The end result is a lean condition for a second. The OEM ECU has this correction already built in. If you go with a bigger throttle body, then this enrichment correction needs to be adjusted to compensate for the even faster instantaneous air flow.
Old Jun 8, 2011 | 11:55 AM
spo001's Avatar
Hi Guys
I thank you very much for the great information you passed me .
To tell you the truth i m very interested in buying some Jenvey ITB's , but first of all i want to be 100% sure that i will be capable to tune the motor ,obviously prior buying them !
Maybe if at least i can get a base map for the ITB's it will help me a lot .
I ve spoke with Hondata and said that they do not have any base maps for the k-pro s2000 ITB's
So if you can help me out . I will be very grateful.
Many thanks again
Nicky
AP1Patrick
Nov 12, 2014 07:39 AM
vstypicals
Oct 20, 2014 12:06 PM
lehighwiz
Oct 29, 2002 08:50 PM
baldy74
Jun 28, 2002 07:07 AM
supernig
Feb 18, 2002 04:03 PM
