Winter storage - low fuel
Old Feb 2, 2018 | 10:33 AM
sammyagg's Avatar
Exclamation Winter storage - low fuel
Hi all,
I am looking for some advise here. Just bought an AP2 in nov 2017. I live in Central NY, so I put the car away in my garage. Everything else is fine, I just realized that my fuel tank is 1/4 or a little less than that. I am scared about condensation. Any suggestions what should I be doing now or when I get the car out in season? Would highly appreciate some expert advise :-)
Thanks!!
Old Feb 2, 2018 | 11:16 AM
afzan's Avatar
I think you will most likely be fine. But for piece of mind you can add 5 gallons with a Jerry can and some fuel stabilizer
Old Feb 2, 2018 | 06:18 PM
cosmomiller's Avatar
Top Answer: 1
Just be sure if you add fuel to top off, don’t go overboard. If you keep topping off the fuel with a standard fuel nozzle, you run the risk of overflow getting into the carbon canister evap system. (According to Billman as I recall)
Old Feb 3, 2018 | 04:43 AM
Chuck S's Avatar
Take her out with a bottle of Sea Foam gasoline treatment with you and go to the gas station. Glug the correct amount of Sea Foam into the tank and fill with 93 Octane. Let the gas pump do the cutoff. Drive home. Store. All based on several years winter storing cars and boats. Your choice of gas stabilizer is probably good too.
-- Chuck
Old Feb 3, 2018 | 07:40 AM
sammyagg's Avatar
Thanks for the response guys, appreciate it!
Old Feb 3, 2018 | 12:37 PM
Conedodger's Avatar
Be sure to check in at the Upstate NY forum! (I'm in Rochester)
Fergal
Sep 23, 2018 11:45 PM
TonysMI4
Aug 28, 2011 11:21 AM
joefish1298
Jul 21, 2010 06:15 AM
siadam
Apr 25, 2009 06:53 PM
Seks
Oct 14, 2003 08:12 AM
