103k on the clock stock trans
Old May 26, 2010 | 06:09 PM
HMFIC's Avatar
Jeez manny!..............i'm actually not surprised lol...
i agree.. maybe just swap in another ap2 man...
Old May 26, 2010 | 06:20 PM
boostedf22c's Avatar
Originally Posted by Spoolin,May 26 2010, 07:16 PM
D@mnit, just limit the power to second gear and it should be fine. LOL I think I only hit full boost in second gear by the top of the gear and mine has been fine.
I'm glad you got it all figured out. I should've kept the stock transmission and slowed the car down.
Old May 26, 2010 | 06:23 PM
Also, to the OP, I've ran a PAR dogbox in my Subaru. They aren't cheap either. Like Rob said, there isn't a cheap solution for the S2k when it comes to driveline.
Old May 26, 2010 | 06:33 PM
Spoolin's Avatar
I wonder if it would be cheaper to just rebuild the tranny with a new 2nd gear and synchro set or get a good used tranny?
Old May 26, 2010 | 06:35 PM
Spoolin's Avatar
I have contacted Jon from TRE to see about a solution with our trannies and if he is willing to come up with something. I'll let you guys know what I find out.
Old May 26, 2010 | 06:37 PM
Spoolin's Avatar
Smartass........Well, I guess I was being a smartass to though.
Old May 26, 2010 | 06:40 PM
What ever happen with the MFactory solution they promised awhile ago?? I thought they were going to have a cheaper solution for the S2k???
The problem is when replacing that Chadd, 2nd gear is on the input shaft itself. So you have to replaced the main shaft, 2nd gear on the counter shaft, synchros, then you don't know if any other damage occurs when all the chunks were floating around. It adds up quick. Believe me, I weighed my options when I broke my first trans. Honestly, it's probably pretty close to the same amount of money if you do all the labor yourself.
Old May 26, 2010 | 06:46 PM
Spoolin's Avatar
^^Gotcha. I wasnt sure how much would go into a rebuild but that makes sense.
Old May 27, 2010 | 03:36 AM
freshs2k's Avatar
Rob! I completely understand where your coming from these motors can handle a lot of power but the drivetrain will not hold even with 500 hp. I could probably do a supra swap and drivetrain for the 12 grand I'm gonna spend on a new set up.
Old May 27, 2010 | 03:39 AM
freshs2k's Avatar
I could by a low mileage trans and put it in but when I make even more power and go to the track it will not last. I also want something that's streetable. Might have to parrt the car out and move on to my next project 2jz e36 m3
