2008 SOS Upgrade Thread
Old Aug 22, 2011 | 01:59 PM
  #41
donaldmejr's Avatar
Originally Posted by package
Any update? Are you satisfied with the reichard pulley?
I've only driven the car around the block one time the other night and only saw 13psi....not sure if it was belt slip or I have a bad map sensor. I will look into it more in a day or so.
Old Aug 22, 2011 | 06:11 PM
  #42
donaldmejr's Avatar
CAI Installed but still needs to be powder coated
Another Picture
Where the catch can is going to go....it will be painted black to match everything else
Fittings and hoses added for the new catch can everything is using #10 AN fittings with 1/2" hoses
It appeared my stock driver side fan came into contact with my radiator and made some nasty damage to the radiator
Another one
So a full blown radiator has been ordered and a fan shourd will be made to fit the slim line fans this is T6061 aluminum
BLV all welded up just needs the powder coating removed and redone
Old Aug 22, 2011 | 06:33 PM
  #43
RAIN H8R's Avatar
great progress!
Old Aug 23, 2011 | 12:30 PM
  #44
Torque Obsessed's Avatar
CAI looks awesome. That BLV location looks familiar!
Old Aug 23, 2011 | 08:31 PM
  #45
RAIN H8R's Avatar
I hope you measured so the intake arm clears a thicker radiator and fan on there...
Old Aug 23, 2011 | 09:48 PM
  #46
donaldmejr's Avatar
UPDATE
We deceided to keep the radiator so we went ahead to just make the fan shroud. I still have to get it painted and new bolts to hold in the shroud. Total cost of the shroud was only 40 buck so if things don't work out with the stock radiator then its not a big loss.
Old Aug 23, 2011 | 10:40 PM
  #47
s2000Junky's Avatar
Nice work^^^ What tool did you use to make all the cuts in the aluminum?
Old Aug 23, 2011 | 11:17 PM
  #48
donaldmejr's Avatar
it was a mini pneumatic sawzall and we made the little spacer at the bottom with a lathe.
Old Aug 24, 2011 | 03:12 AM
  #49
RAIN H8R's Avatar
lookin good!
Old Aug 24, 2011 | 07:15 AM
  #50
donaldmejr's Avatar
thanks guys Im getting anxious to get everything done and hit the track. Im aiming for a 10.99 but I'm sure I'm still under powered for that.
