2mm Headgasket Longevity
So we all know there is endless threads for 3mm headgaskets but I'm curious about the 2mm before I possibly go back to an oem HG.
If you have a 2mm can you list:
How many miles:
Fuel/meth:
Turbo/manifold:
Boost:
Whp:
Engine:
Any additional information:
How many miles:
Fuel/meth:
Turbo/manifold:
Boost:
Whp:
Engine:
How many miles: 80K (20K boosted on 2mm gasket)
Fuel/meth: 91 Oct + 15% Meth
Turbo/manifold: GT3567R / Full-Race
Boost: 19 PSI
Whp: 507whp
Engine: F20C
Any additional information: ARP Head Studs
I think a 2mm is great! I've never had any problems with my gasket. Got it straight through cometic, Checked the gasket for any burrs or imperfections. I think you won't have any problems with a 2mm gasket.
Boost: 19 PSI
Whp: 507whp
Engine: F20C
PT 5857
57,000mi on motor .....2,000 mi on turbo setup
F22c1
12psi
arp head studs
everyone seemed to have issues with the 3mm so I went with the 2mm cometic and sprayed both sides with copper head gasket spray. Works awesome so far no problems at all.
F22c1
12psi
arp head studs
How many miles: 11,500
Fuel/meth: 91 octane
Turbo/manifold: Inline Pro street kit / Precision 5965B-B
Boost: 14-18 psi
Whp: 457HP/275TQ at 16 pounds
Engine: 2.0 with a built head
Any additional information: Ran the car at 14-16 psi when I had first got it and have increased the boost to the 17-18 psi level. (Boost cut is now at 18.8 psi.)
Stock head bolts.
Boost: 14-18 psi
Stock head bolts.
How many miles: about 6k
Turbo/manifold: Vortech SC'd
Boost: 15.7
Whp: 499/311
Engine: Stock F22 bottom end topped by a Stage 3 Port Flow head
Any additional information: Stock headbolts torqued per Helms
Boost: 15.7
Whp: 499/311
I ran the cometic and it lasted about 3 months before it started leaking between cylinders 2&3 at 413whp. i will never use a HG other than oem ever again and i will never install one on a friends car out of respect.
cujet
Jan 31, 2016 01:42 PM
