3mm headgasket
Old Feb 13, 2008 | 08:58 AM
fadiss2k's Avatar
Default 3mm headgasket
Hey guys! Ok, there has been many threads about which 3mm headgasket works and doesnt, weather to use arp studs or oem bolts, etc. etc. etc. I just want to figure out what works and what doesnt. If you have a 3mm headgasket can you please post:
A. Brand of gasket
B. Studs or oem bolts(New or used)
C. Copper spray or not
D. Lube you used
E. What you torqued them to
F. Did you retorque after heat cycle
G. How long has/did it last and @ what psi
Sorry its such a long list. If you can think of anything else that would be useful info please post it up as well!
Thanks
Fadi
Old Feb 13, 2008 | 09:11 AM
TRBOKEV's Avatar
What about 2 mm head gaskets? (Cometic)
Old Feb 13, 2008 | 09:17 AM
rob!'s Avatar
[QUOTE=fadiss2k,Feb 13 2008, 09:58 AM] Hey guys! Ok, there has been many threads about which 3mm headgasket works and doesnt, weather to use arp studs or oem bolts, etc. etc. etc. I just want to figure out what works and what doesnt. If you have a 3mm headgasket can you please post:
A. Brand of gasket
B. Studs or oem bolts(if oem bolts, new or the ones you pulled off)
D. What you torqued them to
E. Did you retorque after heat cycle
F. How long has/did it last
Old Feb 13, 2008 | 09:27 AM
skibum's Avatar
A: inline pro 3mm
B: OEM bolts (reused original bolts that has 25k miles on them)
C: No copper spray
D: Torqued to oem spec
E: Did not retorque after heat cycle
F: So far it has lasted 4 months at 14psi with no issues
Old Feb 13, 2008 | 09:39 AM
fadiss2k's Avatar
old or new oem bolts?
Old Feb 13, 2008 | 09:42 AM
SLW S2k's Avatar
2mm HG cometic (with refreshed head)
ARP bolts
copper spray
oem torque
did retorque after heat cycle
so far so good
Old Feb 13, 2008 | 09:45 AM
Spec_Ops2087's Avatar
A: inline pro 3mm
B: OEM bolts (same bolts as on my stock engine)
C: No copper spray
F: 1+year (10k miles) and 18psi+
skibum's Avatar
Edited my post to include:
Old Feb 13, 2008 | 09:51 AM
TheCarGuy2021's Avatar
I'm not finished with my car yet but here is what I'm using.
A: InlinePRO 3mm head gasket
B: New ARP studs
C: No copper spray
D: 80 ft/lb
E: Will probably re-torque
F: N/A
Old Feb 13, 2008 | 10:27 AM
Soul Coughing's Avatar
A. IP 3mm
B. OEM new
C. Copper spray
D. OEM specs
E. No
F. 8k miles 14-18psi
