4piston CnC ported head and S2 Ultra Intake....Puzzled
Old Feb 11, 2017 | 03:20 PM
meatbag's Avatar
Post both graphs, can help with figuring out whats going on?
Did you have to command more or less fuel at the same boost level as well?
Old Feb 11, 2017 | 09:19 PM
MorngWoodStewie's Avatar
^^x2.... did 4P CNC ur head? Or swap it with a core? Was it shaven at all? Like another person said above, a lot variables right now. I would also check cam timing as a "semi" quick troubleshooting procedure, since you swapped heads n stuff.
It could possibly be lazy as well cuz the port job likes or "shines" with another set of cams not exactly designed for NA.
Old Feb 16, 2017 | 02:12 AM
Honda_Mad's Avatar
Originally Posted by neeman77
Can I see your dyno comparison?
I've attached the graphs, tune needs a clean up still. Been back to the dyno yesterday to check the difference without the intake spacer. Gained abit of torque but lost some Hp. Also ran out of injectors/fuel so we had to stop at 34psi. power is measured in Kilowatt and Newton Meters.
Attached Thumbnails 4piston CnC ported head and S2 Ultra Intake....Puzzled-graph1.png   4piston CnC ported head and S2 Ultra Intake....Puzzled-graph2.png   4piston CnC ported head and S2 Ultra Intake....Puzzled-camtiming.png
Old Feb 16, 2017 | 08:15 PM
So U had to command more fuel. I'd be interested to see same setup with a quick downpipe swap to hood exit.
Did u gain SOME of your lost trq? Or u went on the + side from old stock setup? And now your HP is still chocked?
It's cool to look at these high output setups cause your max HP hits during the power band and not at end. So you have changed the dynamics of flow but not lift and duration and still trying to target that same power band for increases.
That second graph to the right is horrific! No pun intended. Hope u can figure this out.
Can't really tell which way the power band shifted on those graphs.
Old Jun 1, 2019 | 05:45 PM
azian6er's Avatar
I’m just bumping this to see if you ever figured out what was going on. Was it the intake manifold? Or was it the head?
Garrett_si
Aug 27, 2009 01:28 PM
jaeyon00
Jun 30, 2009 05:48 PM
F20Cdriver
Socal Swap Meet
Nov 18, 2008 12:49 AM
duff0000
May 22, 2007 01:39 PM
fltsfshr
Jan 30, 2005 02:42 PM
