500 WHP with a log? Myth or Fact
Old Oct 2, 2009 | 09:55 AM
  #31
MrSmith's Avatar
I can't comment on the pfab kit but I will say that I have been very happy with my UR setup. I have done lapping events beat the snot out of it on the street and have had 0 kit related problems. The setup works as it should.
You can make good power on a quality log kit with the right turbo and tuner. I always chuckle when I see people spend big money on baller tubular kits to make power that's attainable on an off the shelf log setup. Just an observation.
Old Oct 2, 2009 | 09:57 AM
  #32
s2000442's Avatar
You can make good power on a quality log kit with the right turbo and tuner. It always chuckle when I see people spend big money on baller tubular kits to make power that's attainable on an off the shelf log setup. Just an observation.
I do not consider my Mase turbo kit to be a high dollar baller kit, and it will make significantly more power at less boost than any log mani.
Old Oct 2, 2009 | 10:04 AM
  #33
AndyFloyd's Avatar
my log = 350whp @10psi
my tubular = 401whp @10psi
tubular > log.
Log is less efficient and it CAN make the power but its not as easy and the car drives better with the tubular.
Old Oct 2, 2009 | 02:16 PM
  #34
MrSmith's Avatar
Yes thanks for clearing that up lol... you spend more money you make more power. Kinda like how you spend money on a bigger turbo... a ported head... etc. etc. etc.
Look I am in no way saying that a well made tubular setup is not superior. My point is that for most people here using stock motors a log manifold will get you to your 400-500 whp power goal cheaper and with less hassle.
BTW I made 440 on 16 psi 505 on 21 93 octane and now 538 on 100 octane 23 psi. There was nothing difficult about it. I am confident that my setup has 600 in it. Log manifold. Journal bearing turbo. Bottom mount $3600 dollar kit. Plus I can pop my hood tell some poor tubular eltm ball bearing guy on 12 psi oh its only 7 psi gay bottom mount log 260 wheel and maybe take their lunch money.
How exactly does a car drive better with a tubular? Please fill me in I am driving a slow inferior setup.
Old Oct 2, 2009 | 02:54 PM
  #35
jwa4378's Avatar
Member "5thelement" made 500rwhp on an InlinePro log manifold, stock head gasket, and a gt30r turbo... I am 99% sure that was his setup, but he also added water/meth injection...
John
Old Oct 2, 2009 | 04:03 PM
  #36
s_d2k's Avatar
amazing numbers for log mani..
Old Oct 7, 2009 | 06:15 AM
  #37
s2000442's Avatar
Hey it sounds like you have a nice kit and are enjoying your setup which is great!
However, your kit was $3,600 not including injectors, engine management, headgasket or a tune. So looking about $400 for injectors, $1,300 for aem, $100 for headgasket. That is $5,400 ok add $600 for a tune so you are now at $6,000. That assumes your kit is complete and does not require any welding or fabrication for parts to fit and you install all the parts yourself. The labor to pull a head and install gasket is not cheap. I faill to see how I am spending more money on the Mase kit for 400+ whp. He will also retune the map once I data log for no cost also. I will make close to what you are making whp with less boost and no headgasket. I guess to each his own...
Old Oct 7, 2009 | 12:43 PM
  #38
AndyFloyd's Avatar
drives better as in VTEC is now used @ 4600rpm and not 6100rpm. With the log vtec produced a loss in power, with the tubular...it made a huge leap in power as soon as vtec engaged. It just feels better, makes a ton more power, and we were able to add some timing back in and the engine has less exhaust reversion now...@ WOT it feels a ton better. Hard to explain.
Old Oct 7, 2009 | 12:55 PM
  #39
sbrodacz's Avatar
Banned
I made 563 but with a 6165.
Old Oct 7, 2009 | 03:43 PM
  #40
MrSmith's Avatar
anarchy187
Dec 8, 2011 04:55 PM
ScottsS2k
Apr 24, 2010 11:40 AM
03silver2000
Jun 28, 2008 07:32 PM
ERL_S2000
Apr 26, 2008 05:19 PM
