600whp (700hp) s2000
Old May 6, 2019 | 06:12 AM
kumar75150's Avatar
On pump gas, you’re probably limited to low 500s. Maybe mid 500s if you run meth or use an octane booster.
I made 520ish (STD correction factor) with a 62mm turbo, head work, and 93 octane. Never thought about turning it up on e85 or race gas because everyone says the transmission will take a dump.
Old May 6, 2019 | 06:30 AM
DavidNJ's Avatar
Could you add the displacement, engine speed, boost, IAT, and specific turbo used?
Thanks,
David
Old May 8, 2019 | 05:46 PM
kumar75150's Avatar
Thanks,
David
I wish I had all the details. After doing dozens of builds over the years, I pick and shop and don't ask too many questions. What I do know:
stock ap1 bottom end
cnc and upgraded drivetrain on heads (cant remember if it was 4 piston racing who did the headwork)
old school precision 6262
16-17psi (ive seen boost gauge hit 17 when its cold outside in 4th gear)
93 octane (I add a couple ounces of Boostane octane booster for safety when i know im gonna beat on it)
This is the only dyno I can find. This was with 3" downpipe, 2.5" testpipe, 2.5" Tanabe Medallion. I now have 3" test pipe and 3" HKS Single.
The other dyno is Kraftwerks with 12.5psi pulley. I also ran a 16.5psi pulley and made 460whp.
jsenclosure
Feb 21, 2012 07:17 PM
WadeFAB
May 17, 2011 07:05 PM
kawi10r998cc
May 8, 2009 05:38 PM
JustinC
Sep 4, 2007 05:09 PM
3vilmonkey!
Feb 3, 2007 02:56 PM
