740hp stock block
I think these motors really have no breaking point, I mean noone knows where the breaking point is from to much power, noone has bent a rod or cracked a sleeve... I would think on ethanol this motor should last a good while, as long as regular maitenence and oil changes are done, I will most likely be running E85 on my new set up, and am hoping for 650whp...
What post pump fmicron filter and element do you guys suggest for ethanol and gasoline usage
This is impressive no doubt.
I'm awaiting ET/MPH times, and an update at the end of the season on this motor.
This car definitely has enough power to go 9's.
I'm not hating at all, but honestly you have to be kidding yourself if you think the stock motor isn't on borrowed time at these power levels.
Originally Posted by Irishflame27,May 17 2010, 07:10 PM
Would these work with both ethanol and gasoline? I hear that 10 micron needs to be used post filter? What do you sell them for?
