About to go turbo
Old Feb 25, 2014 | 04:09 PM
fapowjones's Avatar
Default About to go turbo
Hello like the title says im about to switch from a supercharger to a turbo. i have a few questions im sure would be cleared up very quickly and i cant seem to find the search option.
first off the car is a 2007 and i have a trackforged kit with a gt35
it already has a walbro 255 in it with 1000cc injector dynamics, but its a returnless style fuel system so at what point do you need to convert it to a return style
what is a conservative amount of boost to run with or with out an aftermarket head gasket and studs on 93 octane
and any other suggestions anybody has for me i'm all ears
Old Feb 25, 2014 | 04:27 PM
baZurk's Avatar
To really utilize the gt35 you will need a return fuel system. Max boost people seem to run on 93 with stock compression is around 15-16 psi
Old Feb 26, 2014 | 02:52 AM
fapowjones's Avatar
Sweet deal what's the normal route for running a return line (modify rail w/fuel pressure regulator or ap1 rail and ap1 hanger or modify ap2 hanger)
And if I were to pull the head put a thicker gasket and studs
Old Feb 26, 2014 | 05:10 AM
baZurk's Avatar
SOS has return system now I believe. Should be very simple to install. Stick with the stock head gasket. People have nothing but trouble with the thicker aftermarket ones
Old Feb 26, 2014 | 03:45 PM
fapowjones's Avatar
Sweet deal then. also got some offset woodruff keys for the cam gears gonna run hondata flash pro greddy manual boost controller and maybe a couple other goodies have to start putting it together I'll probably run a nice pcv/catch can set up. Any other supporting mods power or convenience wise?
Old Feb 26, 2014 | 03:46 PM
fapowjones's Avatar
Thank you very much btw
conors2k
Jul 28, 2014 07:31 AM
brendanj85
Nov 1, 2011 10:17 AM
ILOVEMYAP2
Nov 19, 2010 04:59 AM
Shftat9k
Jan 19, 2008 01:08 PM
REV_29K
25
May 19, 2005 06:56 PM
