Adding aftercooler, clutch, flywheel, intake
Old Feb 25, 2008 | 10:37 AM
nightcrawler7188's Avatar
Thumbs down Adding aftercooler, clutch, flywheel, intake
the last time i had my car tuned, i was peaking at 6-7psi. but the stock clutch was on its way out, as i found out upon leaving the tuner. the clutch started slipping that day. this weekend i'm adding the comptech aftercooler w/ spearco radiator, act clutch, act flywheel, and i got the comptech intake/airbox/filter on now (had the HKS mushroom filter on front of blower before). should i get my car retuned after adding all of this? i'm thinking i should since my IAT will be much lower and i might have a slight drop in boost. opinions? thanks in advance
Old Feb 25, 2008 | 10:48 AM
mase1's Avatar
it honestly depends on how good of a job your tuner did interpolating the fuel map as well as setting up your IAT corrections.
Old Feb 25, 2008 | 01:26 PM
goldenfri's Avatar
What did you tune with? VAFC?
Old Feb 25, 2008 | 02:07 PM
AFC Neo
Old Feb 26, 2008 | 07:40 AM
so as far as my understanding, driving without getting a retune won't hurt my car, but it will run better if i do get a tune. correct?
Old Feb 27, 2008 | 05:02 AM
bump
Old Feb 27, 2008 | 01:15 PM
bump
Old Feb 27, 2008 | 01:37 PM
Soul Coughing's Avatar
so basically, your setup is tuned via a VFPR (adding percentage of fuel for psi seen) and NEO adding a +/- percentage of fuel by tricking the map to see more or less air than whats really there. As the map has a voltage clamp that prevents the stock ecu from seeing boost, the tune for your setup is basically using no real input from MAP sensor to add fueling. So whatever you change with the intercooler and intake may or may not make the tune lean or richer etc...
The IAT's will be determined by the stock ECU, so the timing and fueling amounts will change accordingly, i guess adding more fuel and timing for lower IAT's. I would at least get it retuned, or save up and get at least an emanage, or get an EMS if you want full control!
Old Feb 27, 2008 | 04:48 PM
hmmm it seems to be the way to go...
maybe e-manage ultimate is next on the list. but for now i will get a retune asap. but do you guys think there is potential to seriously harm something in the mean time?
^AnDre^
Aug 28, 2006 10:45 AM
mbilderback
Apr 17, 2006 05:16 PM
str8 6
Apr 27, 2005 10:33 AM
pfb
Jun 13, 2003 10:54 AM
