Advice/ Suggestion on SuperCharger
#22
Don't shoot yourself in the foot because you'll want more power in the future. 400whp is great, but 500whp is freakin fantastic. With SOS, you can upgrade from a N1220 to a N1200 for $65 when purchasing the kit. My SOS kit with a 1200 makes 319ft-lbs up top (DynoJet) and over 250ft-lbs at 6K RPMs with a conservative tune. I'd like to see the new KW kit make similar or better numbers for all the hype, LOL.
#23
#24
Granted that's a TTS kit, but the same blower as the optional upgrade on the KW kit. 500whp, 300wtq, 20psi.
What hype do you speak of? I just see a lot of comments and questions as there is something fairly new and different at hand.
#25
#27
The KW kit is a great kit, but the numbers posted in the link are from virtualdyno. I have virtualdyno plots that go up to ~550whp/350wtq. I just take that with a grain of salt. My point was why just settle for something that is practically maxed out. Boost is addicting.
#28
Check compression / leak down of the engine. If it comes up healthy, then boost away.
If you're doing the new KW kit, you'll be making around 400+whp. You'll need a flashpro to tune it, a heavy duty clutch (get the ACT pressure plate + OEM disk and a lightweight flywheel), ID1000 injectors, bigger fuel pump and a 4bar map sensor, expect to pay about $2.5k on top of the supercharger. Add more cost if you aren't going to install yourself, probably another $1k in labor. These are rough, off the top of my head estimates
Good luck!
Good luck!
common reactor
06-26-2015 11:09 AM
