Advice on Vortech setup
Originally Posted by CRXsir29' timestamp='1348563972' post='22036037
brian crower stage 2 n/a cams seem to work great in our engines, if you were to do that id also do valve springs and retainers, you might be better off getting a novi 1200 instead and running more boost. Thats what id do anyways
I'm also looking into adjustable cams.. would it be more bang for the buck to just do camgears or would it have no comparison to full camshafts?
MORE BOOST IS YOUR BEST BET. anything spent on other stuff will pale in comparison to more boost, especially since you have a built low compression block already.
Originally Posted by SgtDuracell' timestamp='1348587017' post='22036658
[quote name='CRXsir29' timestamp='1348563972' post='22036037']
[/quote]
Yes, build that blower up with the best trim for the most cfm and get the high speed bearing kit so you can spin it faster. Look up what Sideways has done with his VT blower and follow his lead. He is over 500whp with a 9:1 comp motor.
oopsy my bad, but yea like everyone else said, BOOST IT BEST!!!
Originally Posted by camuman' timestamp='1348587378' post='22036681
[quote name='SgtDuracell' timestamp='1348587017' post='22036658']
[/quote]
[/quote]
people say refer to his build thread but i can never find it... the search function on this site sucks. i'd like to know exactly what his build is like
Ok, I'm going to say it's either belt slip and/or your lower comp motor yielding lower boost #'s.
You may want to run a compression check on the motor if you don't know the full history on it.
eglogic
Jun 19, 2006 02:05 PM
