AEM 1052U & Wideband AF Gauge?
Old Jun 29, 2009 | 08:23 PM
Deception's Avatar
Default AEM 1052U & Wideband AF Gauge?
Question for the experts..
I got an AEM EMS w/ UEGO.. it comes with a wide band sensor. That sensor replaces one the O2 sensors in the test pipe.
Do I need to use a wide band AF Gauge (AEM, Prosport) as well? so I would be running 2 wide band sensors total..
thanks
Old Jun 29, 2009 | 08:38 PM
dsddcd's Avatar
Use a Serial Guage then you can see that and more.
Old Jun 29, 2009 | 09:58 PM
soulicious's Avatar
AEM Serial Gauge FTW
Old Jun 30, 2009 | 04:28 AM
roy365's Avatar
What is better the UEGO wideband or the serial gauge with the EMS?
Old Jun 30, 2009 | 04:44 AM
MADjdm's Avatar
Serial with EMS U-box
Old Jun 30, 2009 | 04:58 AM
roy365's Avatar
Does it still utilize the wideband function of the UEGO? Or is it just a data gauge?
I looked on AEM's website, but it doesnt really tell much. Right now i have the UEGO piped into my EMS. What benefit would i get from going serial gauge?
Old Jun 30, 2009 | 05:26 AM
MADjdm's Avatar
You can only read wideband #'s off a datastream gauge if you have an EMS with a built in UEGO controller.
If you do not have U-box EMS, you would need to have the separate UEGO controller type gauge.
The benefit of having a built in UEGO, is that it is already integrated into your EMS without any externall wiring or having to mount a controller somewhere. Plus the added benefit of viewing your A/F in real time via a laptop or AEM Serial datastream and option to datalog etc.
Old Jun 30, 2009 | 06:02 AM
roy365's Avatar
Maybe we arent communicating here well, or i am missing something.
I have the non-U EMS installed. I also have the UEGO wideband gauge installed and wired to the EMS. So i added it after the fact.
Now what benefit or drawback would it be to go to the serial gauge vs. my UEGO gauge?
Old Jun 30, 2009 | 06:10 AM
Deception's Avatar
The Serial Gauge can tell you the AFR, EGT, Knock, Coolant temp, engine speed etc etc.. that what Im going to go with.
Then all I need is a boost gauge & oil pressure and Im set.
s2konroids
Aug 19, 2012 07:47 AM
s2konroids
Aug 16, 2012 04:34 PM
TelosHedge
Aug 18, 2009 08:38 PM
maluch
Jul 28, 2008 05:34 AM
Luke530
Jun 13, 2007 04:34 PM
