AEM Boost Control Question
Old May 29, 2009 | 07:07 AM
Venomous S's Avatar
Question while we are kinda on topic.
In the past with e-manage I got used to just manually loading the maps via the laptop when switching from my pump map to my race gas map
Well, I bought a AEM tru boost controller gauge, I believe that with this controller you can have 2 boost settings, now will this or can this gauge be incorporated into the AEM software so it changes the maps as well? or we'll the controller ONLY change the amount of boost?
Old May 29, 2009 | 12:26 PM
300sx's Avatar
Originally Posted by Venomous S,May 29 2009, 07:07 AM
I'm about 99% sure there's no output on the gauge that you could use to change maps. Would be cool though.
Old May 29, 2009 | 12:42 PM
300sx's Avatar
[QUOTE=Evans Tuning,May 28 2009, 01:31 PM] Its best to start with a conservative curve on the error duty table.
Old May 29, 2009 | 06:40 PM
siadam's Avatar
Originally Posted by Evans Tuning,May 29 2009, 11:12 AM
The target boost comp table is not defined properly if you are entering a load value for the "hi" input, and you are not reaching it.
Well thats what I don't undertand.
It is showing approx 12lbs in the boost switch target, but I am hitting 15lbs.
So I'm actually exceeding the value?
Old May 29, 2009 | 06:48 PM
300sx's Avatar
He's referring to the table at the top right on this pic...
http://siadam.com/stuff/boostmap.jpg
Although that is in kPa, if it were (or is now) in PSI you would just go to the 12psi breakpoint, or closest to it, and lower the duty %.
If you want to switch to PSI go to configure / units / load units
Hope that helps
TerminatioN
Jun 6, 2012 01:23 PM
jaundice
Jan 5, 2010 03:06 AM
03silver2000
Apr 28, 2008 06:28 PM
geists2k
Aug 28, 2006 11:33 PM
m00s3
Jul 19, 2006 05:07 AM
