AEM EGT
I'm not running an EGT yet but depending on the probe length I can see it fitting in some tubular manifolds.. I've seen it run on the downpipe as well. Does AEM list the overall probe length? You don't have to use the AEM one either, any probe with a 0-5v output will work.. The AEM doesn't look plug and play, so either way you will need to splice into the factory wiring or use the D connector on the EMS
