AEM EMS 2STEP Settings
Old Sep 27, 2009 | 11:04 AM
CaseyGW's Avatar
yeah the further you retard the timing the more likely it is to do that. basically youre getting it to a point where the timing is so late that its igniting unburnt fuel in the turbine housing/exhaust
Old Sep 27, 2009 | 11:26 AM
Ian300D's Avatar
I think mine is set at like 4000rpm and I can build I think 5psi. I'm gonna have to look again, either way my launches are pretty efficient on the tirespin/grip scale.
Old Sep 27, 2009 | 01:52 PM
spectacle's Avatar
Hmmm
I'd like to play with this in Kpro. I have no idea how to set it up though
Old Sep 27, 2009 | 08:01 PM
Tech7427's Avatar
hmm thanks for all this info.,. when i get the car back up and running ill be sure to play with this haha
Old Sep 27, 2009 | 08:31 PM
Irishflame27's Avatar
Does this automatically work of the cruise control cancel switch on the clutch pedal?
Old Sep 27, 2009 | 08:41 PM
smirfs2k05's Avatar
vids... =]
Old Sep 28, 2009 | 02:52 AM
Tech7427's Avatar
The "switch" is always on. That means aem looks at the variables in the settings.
So as long as the car is below 10mph ( user variable) the car will enter 2 step rev limiter.
Old Sep 28, 2009 | 02:54 AM
RAIN H8R's Avatar
correct.
Thats how I have mine.
Old Sep 28, 2009 | 03:11 AM
Spec_Ops2087's Avatar
I've mentioned this before and figure I should mention it again before everyone goes out and tries this, by using the 2step you run the risk of dropping a valve due to spring failure. Its happened on a few motors already.
You want fireballs aka 2step(since this probably the biggest reason for most people), you'll need a upgraded valvetrain otherwise your on borrowed time.
Old Sep 28, 2009 | 07:14 AM
wadzii's Avatar
Banned
i have setup anti-lag on 100's of vehicles, the only reason you end up with damage is if its already broken from the get go or if you hold it on the anti-lag for like 20 minutes you will burn something up. For its purpose of launching the car it's fine.
