AEM EMS 2STEP Settings
Old Aug 24, 2011 | 05:43 AM
  #51
siadam's Avatar
Originally Posted by package
I mean the redline rev limiter
Your rev limiter should be based on your motor/head/cams/etc, not some arbitrary number. f20:9k, f22c:8200. Go from there.
Old Aug 24, 2011 | 07:50 AM
  #52
package's Avatar
I'm confused. My rev limiter settings are fuel cut 8800 and ignition cut 8700 rpm. My 2step is 4000rpm both of them. Are this settings ok or i have the make any corrections? My setup is novi 1000, 3.0 pulley, fmic and aem ems 1052u
Old Aug 25, 2011 | 10:31 AM
  #53
DBXFX's Avatar
Since you are SUPERCHARGED and not turbo'd, I would think that you would want your fuel cut before the ignition cut on both limiters. With the way you have it now, at 8700 rpm, you are shooting fuel in but not igniting it. I dont know who tuned you, maybe they did this for a reason. But I don't see why. Your 2 step seems fine; have you tried it out?
The only reason for you to have a 2 step would be to get a consistent launch. So, the only way to know what rpm to set it at is by trial and error. As far as the rev limiter, I wouldn't go past stock redline on a stock motor unless you are ready to pay for the consequences. Too high a redline can cause serious valvetrain problems eventually dropping a valve. If you have a built motor ask your tuner.
Old Aug 27, 2011 | 04:29 AM
  #54
package's Avatar
If i set the fuel cut before the ignition cut don't i built up heat in the motor?
About the 2step, you are right. I want it just for launch. I tried a couple of rev limits. I set it up according to the raod surface.
My stock redline rev limiter was 8900 since i have an ap1 v2. So i have a stock motor and when we installed the supercharger we set the rev limiter at 8700 rpm.
Old Sep 7, 2011 | 10:52 AM
  #55
myflys2k's Avatar
Bump this back up
Im curious too. My ems rev limiter is also set ignition at 9100 and fuel at 9200. I have yet to test the 2step limiter but its set fuel 6500 ignition 6k, medium cut,
Old Sep 8, 2011 | 07:01 AM
  #56
B5254T4's Avatar
Had to go 7000rpm on the MT´s, tried 6000 but needed higher after a few burn outs.
Old Jan 11, 2021 | 04:27 AM
  #57
RolanTHUNDER's Avatar
Originally Posted by CaseyGW
i messed with mine a bit.
i have it on 7 out of 10 for the harshness (cant remember exact name)
always on
6000 ignition cut
7000 fuel cut
6025 ignition retard
7mph or under
the ignition retard pretty much determines how much boost youll make from my playing around with it. if i had it at 6000 i could make a couple more psi than at 6025. i can make 5-7psi as it sits. just a greddy kit, 3" inline pro exhaust and ems
Bump for the AEM 2 step crowd!
If fuel cut is after ignition cut when 2 stepping it would be shooting them nuclear flames
Old Jan 12, 2021 | 05:17 AM
  #58
Anyone have first hand experience with 2 step damaging their valve train?
Old Jan 14, 2021 | 06:40 AM
  #59
johnckeen's Avatar
I was going to say the same thing, surely this is going to melt exhaust valves and just plain bad for the engine?
Old Jan 18, 2021 | 12:57 AM
  #60
None of that. I heard one user on here say over and over again that the springs are what could fail. Now I'd like to know if anyone has ever had that happen and after how long were they 2 stepping, how many cycles, years, etc?
Apparently turbocharged cars would have a higher risk of heat damage due to the exhaust manifold turbo setup. So the manifold itself is at risk not so much the exhaust side of the valve train...??
sproket13
Jan 10, 2015 10:08 AM
asthmattic37
Jun 17, 2010 05:32 AM
godzilla_753
Apr 16, 2010 07:58 AM
jethatch
Jan 13, 2010 10:19 PM
jwkim
Mar 13, 2005 08:49 PM
