AEM EMS 2STEP Settings
Old Sep 29, 2009 | 03:03 AM
  #31
Spec_Ops2087's Avatar
Originally Posted by camuman,Sep 28 2009, 12:37 PM
could this have been an ap1 problem as they had the crappy retainers?
No, it's the springs that fail in this case so AP1 / AP2...doesn't matter.
Old Sep 29, 2009 | 12:13 PM
  #32
Spoolin's Avatar
No problem man. I just wanted you to know the truth about what could happen over time with the stock valvetrain. Id hate to see someone drop a valve and ruin a good engine because they didnt have the correct information about things. Just make sure you pull the valve cover every once in a while and check the retainers and things for cracks or signs of valves slipping out of the retainers. If you see any weird things, its time to get the valves serviced before a major catastrophy happens.
Old Sep 29, 2009 | 01:21 PM
  #33
boostedf22c's Avatar
Old Sep 29, 2009 | 01:25 PM
  #34
RAIN H8R's Avatar
Originally Posted by boostedf22c,Sep 29 2009, 04:21 PM
Old Sep 29, 2009 | 06:30 PM
  #35
o'malley_808's Avatar
haha love your sig picture boostedf22c !
Well that sucks. Seems retarted that our engines are strong enough to hold 400whp with boost without even touching the engine and yet cant handle a bit of 2step.
Like someone else mentioned tho can we not set this up as a secondary rev limiter without the popping?
Wouldnt that be the same as the oem ignition cut rev limiter which surely cant be that bad for the engine?
Most newer vehicles have a secondary rev limiter when the vehicle is not moving to avoid engine damage can we not set something similar up in AEMPRO?
Old Sep 29, 2009 | 09:10 PM
  #36
neeman77's Avatar
Yes you can, I had mine set up with an ignition cut at 6200 rpm and fuel cut at 6400 rpm with no ignition retard.
Old Sep 30, 2009 | 02:53 AM
  #37
RAIN H8R's Avatar
Thats how I have mine setup. I have no popping at all...
Old Sep 30, 2009 | 03:39 AM
  #38
OEM rev limiter is a fuel cut not ignition cut / retard. Of course if you use the OEM style limiter it'll be much more safe but what's the point? By cutting the fuel your not going to build any boost. There is a reason why honda doesn't use ignition related rev limiters...again, your on borrowed time so just understand that risk.
Old Aug 16, 2011 | 03:30 PM
  #39
Anyone have any updated settings? I havn't heard of any recent valvetrain failures from 2step? Post up your settings if possible!
Realstreet post here
Old Aug 16, 2011 | 08:31 PM
  #40
siadam's Avatar
In for settings.
- Sent from my iPad2 using Tapatalk
