AEM EMS talk.
Old Aug 10, 2005 | 10:22 PM
f20kills's Avatar
Originally Posted by double11,Aug 10 2005, 04:38 PM
This is most likely an issue with the fuel trim vs. AIT. Found under 'Fuel>Advanced Fuel>Fuel Trims>Air Temp Fuel Corr Table. From there you can either make changes in the table or graph form, which ever is easier for you to use.
I bet you are getting a little heat soak and the engine is getting hot air for a little while after you've let it sit for a little while after driving.
your other issue is probably decel fuel related, but you should be able to clean it up with the base map; unless you are running too large of injectors.
Maybe thats my problem, too big of injectors(750cc).
Scorpion, you running large injectors too?
Thanks double11
Also, if my engine where to be getting hot air from sitting, wouldnt it run richer and not leaner from the heat?
Old Aug 11, 2005 | 02:43 AM
Scorpion's Avatar
I'm running 650's. I think that's you'd have to be running 1000+ injectors to have a problem with them.
AlpineFD
Aug 16, 2018 12:37 PM
lotus7racer
May 25, 2010 06:03 PM
SentTwoKill
Sep 6, 2009 04:01 AM
djap1
Mar 29, 2007 05:03 AM
Nhan
Dec 6, 2006 08:08 PM
