Aem infinity 6 auxiliary hookups
Old Dec 16, 2015 | 03:50 PM
Spoolin's Avatar
Default Aem infinity 6 auxiliary hookups
Anyone know how to hook the 12 position trim pot up to the infinity? I know where the 5v and ground go but where do you connect the signal wire to on the auxiliary connector? Any of the other analog inputs besides the oil and fuel pressure ones I'm using?
Also, how does this thing work within the infinity setup and tuning? Can I have position 1 (farthest to ccw) be for a gas tune, position 2 be for e85 and possibly position 3 be for c16 and then the following 4-12 position be for boost with each click be like 5 psi increase? Or can I only dedicate this switch to one thing at a time like all positions have to be for boost or fuel changes or whatnot? If I can use the switch like I mentioned first with fuel changes on 1-3 and then boost changes on the remaining 4-12, what needs done within the aem to achieve this being that only one signal will be hooked up to the infinity? How would it distinguish between each click of the dial to know what is being selected next?
Old Dec 19, 2015 | 09:06 AM
Spoolin's Avatar
Does no one know anything on this?
AFK-S2K
Mar 22, 2016 08:43 PM
Chiung
Feb 24, 2016 02:09 PM
Blucky87
Oct 13, 2011 08:16 AM
Spoolin
Jun 9, 2006 12:30 PM
Hobbyholic
Sep 28, 2005 07:12 AM
