AEM meth kit battery drain issues
My injector 9 output (immobilizer light) is turned off and it still does it. It goes out when the ignition is on and I can turn it on and off by configuring outputs, but for some reason when the ecu is off it is pulling a ground there. This is a series 2. Anybody else's series 2 do this?
Yes sir! Ridiculous design! You have to put a relay to cut the positive power lead to the controller and the pump otherwise it draws on your battery! Haven't had any drain issues since installing a relay!
I will take a look tomorrow and see if/how much current it's drawing when powered off.
