AEM sending unit values for serial gauge?
Old Dec 28, 2009 | 08:28 AM
Irishflame27's Avatar
Default AEM sending unit values for serial gauge?
Hey,
I have an AEM 150psi oil presure sending unit that i wired into the ADCR13 input, but im having a hard time figuring out how to input the values and parameters to make the sending unit display thru the serial, does anyone have any insight on this?
Old Dec 30, 2009 | 03:05 PM
bump
Old Dec 30, 2009 | 06:36 PM
Kirpich's Avatar
Well, you need to collate the 2 instruction manuals together. The oip pressure sending unit has the + and the ground. + from the Serial gauge, and the ground going to ground. But for better precision, the ground should go back to the serial gauge. The varying oil pressure makes a potentiometer change its resistance, and the gauge measures it. Then, knowing what resistance in Ohms equals to in psi, it displays accordingly.
That's the basics.
Now, you need to know what's the corresponding range in Ohms is to 0-150psi for that particular sensor. That way, say 360Ohm is 0 psi, 180Ohm is 75psi, and 0Ohm is 150psi. Or some such thing. Is there a way to setup these parameters in your gauge?
Old Dec 30, 2009 | 07:39 PM
dammitjim's Avatar
Does oil pressure show up as an option in the pull downs in AEMpro under View -> Telemetry Setup ? Does your gauge work already for other stuff?
rtboy10
Jul 31, 2016 07:04 AM
Moddiction
Jan 18, 2014 04:40 PM
Irishflame27
Jun 15, 2010 01:30 PM
mys2k3
Jul 12, 2009 04:30 AM
S2Krazee
Sep 26, 2008 11:44 PM
