Aftercooled Vortech Supercharger
Old Aug 12, 2007 | 11:29 AM
Slows2k's Avatar
If you have to add coolant then you've got a leak, or the pump isn't mounted correctly and is not bleeding the air from the system.
Most use coolant/water mix because it won't freeze.
Old Aug 12, 2007 | 11:31 AM
Ty.'s Avatar
Ty.
how big is the resivoir on the vortech kit?
Slows2k's Avatar
Not very big, It may hold a little over a quart.
Old Aug 13, 2007 | 07:43 AM
73Zero's Avatar
Originally Posted by Sideways,Aug 11 2007, 03:57 PM
It is a waste of time and money.
As an owner of Tech2's interFOOLer, I can honestly say that in retrospect I should've just saved the money and time, and used the stock Comptech heat exchanger. Comptech themselves said that the bigger Tech2 unit wasn't going to make any noticeable performance difference, and that all their R&D proved that their stock heat exchanger was properly sized for this application.
On the other hand, it does look pretty blingy behind the front bumper...and that's about it.
financedirect
Nov 25, 2009 10:13 AM
dalink
Dec 22, 2007 09:40 PM
Kondor999
Nov 19, 2007 01:32 AM
common reactor
Nov 21, 2006 07:20 AM
