Air/Fuel Problems here
Old Nov 14, 2008 | 11:50 AM
  #31
JoeyBalls's Avatar
Originally Posted by REVHIR,Nov 14 2008, 10:03 AM
Why doesn't anything like that happen when you run out of gas?
because when you run out of gas there is NO FUEL, not just enough to ignite and explode
Old Nov 14, 2008 | 11:54 AM
  #32
TRBOKEV's Avatar
Ummmmm
Heres a good writeup on detonation: http://www.tricktuners.com/detonation_explained.htm
Old Nov 14, 2008 | 11:57 AM
  #33
JoeyBalls's Avatar
Originally Posted by TRBOKEV,Nov 14 2008, 12:54 PM
Ummmmm
haha I know what detonation is, I learned all about that and Pre-ignition back in my student pilot days
You callin me stupid haha
Old Nov 16, 2008 | 04:14 PM
  #34
REVHIR's Avatar
Its really slow right now so I am going to let the car rot in the garage until I get MONAY. Most likely the fuel pump or bad injects right???
Old Nov 16, 2008 | 04:31 PM
  #35
JoeyBalls's Avatar
Hey my car was running very lean with a BAD TPS, and on some cars it takes a while for the related CEL to come on, check the voltage .45v at idle 4.5v at WOT
Old Nov 16, 2008 | 06:48 PM
  #36
Artisan7471's Avatar
Detonation is more related to timing than Afr's, and is allways bad. You can detonate with good afr's and you can also detonate with poor afr's. However if you are detonating with poor afr's you are more likely to damage the engine. Detonating with rich condition while still bad, is better because the rich afr will burn at a lower temp than the lean condition. This is one of the reasons why it is wise to run at 10 to 11 afr under boost. If detonation does accidently, occur due to bad fuel or over boost, then you are alittle safer.
Old Nov 16, 2008 | 08:14 PM
  #37
s2000Junky's Avatar
Or FPR
Old Nov 16, 2008 | 08:41 PM
  #38
REVHIR's Avatar
Im guessing that means Fuel Pressure Regulator. No flames please. What does that look like?
Old Nov 17, 2008 | 08:08 AM
  #39
Elite's Avatar
are you running a injector driver with the new injectors?
Old Nov 17, 2008 | 11:25 AM
  #40
s2000Junky's Avatar
Thats right.
Sorry I dont have a pic of mine. Most likely is located near your clutch resivor. and is about the size of your fist. Mine is a Comptech brand and has an adjustable threaded post with a lock nut on top. The unit is billet aluminum.
