Andy's CR PFAB Turbo Build...so it begins.
#42
I can smell the finish line Got everything mounted up
Thanks speedfactory for the manifold bolts. Can hardly see them but i really like the burnt titanium lol.
Also got all my oil and vacuum lines plumbed. I ended up using vibrant push lock fittings for my vacuum stuff with 1/4" p.e. tubing. Also put rubber hose over the tubing for extra protection against manifold heat.
I mounted the boost solenoid to the alloycraft heater bracket. Also running a vacuum block up at the center of the firewall.
Heres a pic of the bov plumbed using the pushlock fittings. The tubes slide in very easily...hopefully theyre not prone to leaking. Hopefully ill have some more time over the long weekend to finish her up.
alright, pinning the b16 port for the solenoid on the ecu harness was a bitch. It wouldve gone by so much quicker if i had known from the beginning theres a stupid locking clip that needs to be popped in order to install/remove pins...
anyway, also got my defi boost gauge and controller installed. Fed through the passenger side firewall then across under the dash from the interior to under the steering wheel.
also switched the ignition on a few times and fuel pump primes and no leaks at the fuel rail!
if all goes well i should be able to fire her up tomorrow...on new years day!
by the way where do others place the iat sensor? Oem location near the throttle body?
#44
Also, i found an e85 fb turbo kit map and it started right up and seemed to idle okay. However i dont have my o2 sensor hooked up since its essentially an open header right now until i can get it to the shop to finish up my exhaust work. Do you think itll be okay to drive it to the shop staying under 3k rpm and out of boost?
#47
Fired her up briefly yesterday! gonna redon all my couplers and clamps as straight as i can before taking it to my tuner this week. Gonna have him put in some supertech goodies in the head before the tune.
#48
without at least a turbo blanket don't be surprised if that melts. Not exactly sure what the difference between dry carbon pieces and regular but I have read even carbon fiber hoods with setups similar to this having fiber separation n melting issues.
