Anyone running a drain back catch can?
Old Jun 27, 2014 | 03:53 PM
staylor725's Avatar
I finished my catch can drain back setup replaced my radiator hoses and crank dampener while i was at it.
[attachment=61715SCN0272-001.JPG]
[attachment=61716SCN0271.JPG]
[attachment=61714SCN0270.JPG]
Attached Thumbnails Anyone running a drain back catch can?-dscn0270.jpg   Anyone running a drain back catch can?-dscn0272-001.jpg   Anyone running a drain back catch can?-dscn0271.jpg
Old Jun 30, 2014 | 07:37 AM
siadam's Avatar
Sounds like a great idea until you actually look in the catch can and see the nasty oil residue, not to mention on e85 it's even worse.
I'll prefer to drain it manually.
For a regular, mostly stock car, it's probably a great idea.
Old Jun 30, 2014 | 03:04 PM
boostedf22c's Avatar
I don't know why you'd want to drain back the crap that ends up in the catch can.
Old Jul 1, 2014 | 05:23 PM
staylor725's Avatar
Well if you mount you catch can lines in front of the valve cover the catch can will over fill a lot faster than you think, so that's why I drained it back. The catch can only gets nasty because the fuel vapor and moisture in the little bit of oil In the can never gets hot enough to burn off that stuff. What do you think happens to all blow by vapors going past the rings some goes in the oil and some goes in the catch can the only diffence is the temp of the oil in the pan vs the catch can.
Old Jul 1, 2014 | 07:06 PM
Too each their own.
If you are filling your catch can up fast enough that's it's inconvenient to just empty it, you should probably look it to what's causing that. There are lots of things that can attribute to that.
I can make 30 1/4 mile passes at 1200hp+ on methanol and not fill my can up.
bikky
Sep 3, 2014 07:35 AM
markS2kcU
May 19, 2007 10:00 PM
lazykiwi
Sep 12, 2006 08:49 AM
pellisS2k
Feb 9, 2005 07:33 PM
krazik
Feb 9, 2005 11:56 AM
