AP1 S2000 SC HEAD BUILD? OR BONE STOCK?
Old Jul 6, 2015 | 04:10 PM
youngkilla's Avatar
Default AP1 S2000 SC HEAD BUILD? OR BONE STOCK?
How many of you ap1 owners have built your head, being supercharged or upgraded the oil banjo bolts to ap2? Or just running on a complete bone stock f20c? Please list your setups thanks!
Old Jul 6, 2015 | 05:49 PM
lude92_si's Avatar
comptech supercharged setup 15psi 405whp stock head.
turbo setup 600+ whp 23psi ap2 retainers everything else stock.
I also added ap2 oil jet bolts before my 1st setup. everything else on my ap1 motor is stock.
Old Jul 6, 2015 | 06:03 PM
cheddaboy's Avatar
Stock ap1 long block 315ish whp comptech s/C with over 50k miles untuned. Motor runs perfect. Doesn't burn oil (Motul 8100). And I've driven a 5 hr round trip and ran this car at the track twice so far. No issues yet.
Old Jul 7, 2015 | 10:17 AM
hvAlfaWant_S2000's Avatar
MY01
Vortech V2 S/C 392whp @ 14 lbs
Bone stock block, internals, and retainers(not cracked after last check 2 years ago)
Recently installed AP2 banjo bolts after running 9 lbs for over a year.
Old Jul 7, 2015 | 10:42 AM
tom153's Avatar
Ran 8, 12.5, 14.5, 16.5psi on a completely stock '01 motor while revving it to 9k. Exhaust valve guides were shot at ~105k. Installed new guides, supertech inconel valves, supertech valve springs with titanium retainers and ARP head studs; making a hair under 24psi @ 9300 RPM now.
Old Aug 13, 2015 | 03:05 AM
Totalpkg's Avatar
Upgraded AP2 jets, retainers...otherwise bone stock internals. I have a couple bolt ons like header and intake manifold...but internals and block are stock.
Old Aug 13, 2015 | 03:50 AM
Chitoki's Avatar
Cant beat OEM for reliability. I did a full head build, ferrea comp plus valves, BC dual springs and afew other tricks.... Just recently rebuilt my head and went back to ALL oem parts,the ferrea valves went out of round and caused the head to lose compression. We also noted premature wear on the valve guides, never had those problems with oem internals.
Old Aug 13, 2015 | 03:53 PM
The more I read, the more I see OEM for internals are the way to go on any rebuild.
Old Aug 13, 2015 | 06:14 PM
umair's Avatar
100 percent stock head and block. So far i am running 461whp at 16psi. No problems. Car is capable of doing 27psi but im having fun at 16. I run 19psi occasionally. As well. As long as the ap1 retainers are not over revved they are fine.
I bought supertech springs and retainers but opted not to install them because after reading more and more i found that oem is the way to go.
VashTheStampede
Feb 14, 2018 05:35 AM
ls/vtec
Jan 23, 2015 09:11 PM
passmans2kny
Oct 28, 2014 01:39 PM
Evo and S2k
Jan 19, 2012 08:16 AM
1sickGixxer
Nov 2, 2010 11:41 AM
