baZurk's boost build
Old Jun 1, 2014 | 04:46 PM
  #461
baZurk's Avatar
There is only slight side to side movement. If it was an old turbo I would even say it was normal. There is no in or out slack and the shaft stays perfectly centered when the car is idling.
Old Jun 1, 2014 | 04:50 PM
  #462
herecomesboost's Avatar
Are the blades making contact with the compressor housing at all (scratches on the inside of the comp housing)?
Old Jun 1, 2014 | 05:07 PM
  #463
baZurk's Avatar
I don't believe so Kyle although I will have to get a better look tomorrow morning. The radiator in the DD has cracked so the s2k has to carry those duties for a few days.
Old Jun 1, 2014 | 05:44 PM
  #464
lude92_si's Avatar
Matt my brand new turbo has some side to side and it has 0 miles on it. I'm guessing this is normal as long as its not touching/hitting the compressor housing
Old Jun 1, 2014 | 05:47 PM
  #465
baZurk's Avatar
Well that puts my mind at ease. I figured once the bearing have oil pressure to them then the shaft will stay pretty centered. The thing that concerned me was I could hear it click a little when I pushed it side to side.
Old Jun 2, 2014 | 06:48 AM
  #466
baZurk's Avatar
So the fins aren't contacting the side of the inlet. Maybe I am just paranoid.
Old Jun 2, 2014 | 07:36 AM
  #467
lude92_si's Avatar
Yeah mine does the same. No in and out but it will move side to side. I wouldn't worry about it Matt unless its smoking bad or hitting something
Old Jun 2, 2014 | 07:38 AM
  #468
baZurk's Avatar
Thanks Josh. Are you gonna make a build thread anytime soon?
Old Jun 2, 2014 | 07:52 AM
  #469
lude92_si's Avatar
I should lol but just have crap cell pics. I'm still stuck on my fuel setup. Grrrr so many people telling different things. I will try to start a build thread. It's getting close to being done. After I figure out what pump and injectors to go with
Old Jun 2, 2014 | 07:53 AM
  #470
lude92_si's Avatar
Getting there
