Berk HFC and the CEL
Old Nov 3, 2010 | 09:37 PM
mezzfin's Avatar
Default Berk HFC and the CEL
Just checking to see if anyone else is popping a CEL ("unexpected oxygen difference") on their Berk 63mm HFC. I ran it for about 2500 miles just fine until the CEL came on. The code was as stated, so I had it reset. Came back on 140 miles later - same code. It has been suggested that my best option is to swap the HFC for the OEM cat shortly before I get smogged (Oregon - data port only), then swap it back out for the HFC for the next 2 yrs until it is time to get smogged again. I thought the Berk HFC was supposed to pass smog, but I won't get anywhere with a CEL on.
I am running the GReddy kit on my DBW '06 with Hondata's Flashpro. Thoughts?
Old Nov 3, 2010 | 09:51 PM
EternalLx's Avatar
You try one of those CEL eliminator things used for testpipes first.
Did you update the flashpro to the latest software?
I remember a thread not too long ago about a software issue on the o2 CEL issue. (If i remember correctly)
or the cheapest way would be just to turn it off completely via flashpro unless you need it for emissions.
Also I know you have the Berk HFC but another issue that MY06+ guys had with Asura HFCs were that the opening for the o2 was covered for some reason.. I drilled mine out and havent had a problem since.
xristoforoS2000
Κινητήρας - Μετάδοση - Περιφερειακά
19
Jun 2, 2018 12:20 AM
DaMan22
Feb 23, 2012 04:58 PM
Driven
Jan 15, 2012 07:50 AM
