Injectors and pulley before EMS
Old Nov 3, 2010 | 03:12 PM
Kris AP1 S/C's Avatar
Default Injectors and pulley before EMS
I am having an AEM EMS series 2 installed soon and dyno tune. I have a Vortech V2 and I'd like to install some 650CC injectors and 9psi pulley before I get to the shop to save some money.
Would it be safe to do these mods without the AEM if I take it easy and stay out of V-tec as much as possible for a day or two?
Old Nov 3, 2010 | 03:33 PM
Moddiction's Avatar
Former Sponsor
Pulley yes, injectors I don't think so really. Will drive horrible. I would def do the pulley and just make sure to not go high into boost.
Old Nov 3, 2010 | 04:08 PM
arazs2k's Avatar
injectors can be installed at the dyno shop where ur ganne tune it so ull be safe. to much fuel is not good.
Old Nov 4, 2010 | 05:59 AM
Gernby's Avatar
Former Sponsor
I agree with those above. Install the pulley at home, then avoid full throttle. Injectors are easy to install, but the stock tune won't work with them.
Old Nov 4, 2010 | 06:22 AM
Jacko's Avatar
You mentioned you wanted to save some money. Does that mean you are having the shop install EMS,Injectors, & the pulley? If that is the case how about installing everything yourself and getting a base map for the EMS to limp the car to the shop ?
That's what I did with my turbo kit and Jeff Evans. Installing the stuff yourself will save you money and give you better knowledge so if something breaks down the road you'll be better prepared to trouble shot it and fix it yourself.
Old Nov 4, 2010 | 06:41 AM
Thanks for the suggestions.
I will install the pulley at home. The last time I removed the belt, I had to drain the coolant and remove a hose to reach the tension pulley lock nut. It was a pretty big job, so maybe I'll save some money.
I'll just have the shop install the injectors. They are an hour and a half away and they already have the AEM EMS at their shop, so I can't install it first and load a base map.
Old Nov 4, 2010 | 06:49 AM
Deception's Avatar
injectors take 5 mins to install, do those at the dyno shop
the pulley can be installed, but just leave the belt off and drive to the shop w/ no boost
Old Nov 4, 2010 | 07:07 AM
Jacko's Avatar
Originally Posted by Kris AP1 S/C,Nov 4 2010, 10:41 AM
The last time I removed the belt, I had to drain the coolant and remove a hose to reach the tension pulley lock nut. It was a pretty big job.
Really wow what kind of S/C kit ?
lazykiwi
Feb 20, 2007 04:11 PM
news2kroller
Sep 27, 2006 06:54 PM
gusrock77
Aug 9, 2006 12:52 PM
Akilldema
Apr 9, 2006 06:32 AM
SC-S2000
Feb 20, 2006 10:02 PM
