Best AFR to achieve whilst in boost
I believe a pretty widely accepted range is 10.5-11.5:1. If you're the type who errs on the side of caution then you can aim for the lower side of that range. a few guys running lower boost safely aim a bit higher (low 12's), but with 18 pounds I would probably shoot for around 11.
These values are for a pre-cat wideband (not the tailpipe sniffer kind) and remember that every wideband can measure slightly different values.
I don't think it matters what fuel you are using. You can run 11.5-11.8 safely with any fuel. Don't worry about leaning it out to make power cause you won't. You can run 11.0 vs 11.8 and you won't gain but more than 2-3 HP. Some will tell you that E85 can run leaner but why risk it? Just my opinion.
Many thanks
