Best AFR to achieve whilst in boost
Old Jun 20, 2013 | 03:00 PM
Middlesbrough's Avatar
Default Best AFR to achieve whilst in boost
Hi guys...
What's are your thoughts of the best AFR to run with a 18psi charger through the revs?
Thank you!
John
Old Jun 21, 2013 | 01:12 AM
CoolGuy094's Avatar
I believe a pretty widely accepted range is 10.5-11.5:1. If you're the type who errs on the side of caution then you can aim for the lower side of that range. a few guys running lower boost safely aim a bit higher (low 12's), but with 18 pounds I would probably shoot for around 11.
These values are for a pre-cat wideband (not the tailpipe sniffer kind) and remember that every wideband can measure slightly different values.
Old Jun 21, 2013 | 06:43 AM
Timmay208's Avatar
also going to depend on what fuel you will be running
Old Jun 21, 2013 | 09:43 PM
siadam's Avatar
Just gonna post this too.
Sent from my iPhone 5 using Tapatalk.
Old Jun 22, 2013 | 03:09 AM
lotus7racer's Avatar
"best AFR to run with a 18psi "
decrease timing to be safe !
Old Jun 22, 2013 | 05:19 AM
1SlowSi's Avatar
I don't think it matters what fuel you are using. You can run 11.5-11.8 safely with any fuel. Don't worry about leaning it out to make power cause you won't. You can run 11.0 vs 11.8 and you won't gain but more than 2-3 HP. Some will tell you that E85 can run leaner but why risk it? Just my opinion.
Old Jun 22, 2013 | 05:18 PM
Hey, I'm running with no cat. Using the berk 3" header back... So this is classed as pre cat all the way right?
Many thanks
Old Jun 22, 2013 | 05:22 PM
Hi,
It's 98 RON 93 Octane
thanks for all advice
nguyen365
Jul 4, 2017 05:37 PM
jpetch05
May 30, 2014 06:22 AM
mattie170
Jan 8, 2013 07:37 AM
JoeyBalls
Sep 14, 2008 07:32 AM
blackey
Jul 27, 2007 08:21 AM
