Best Turbo to Swap In
I actually just got off of the phone with InlinePro. Tom was able to offer me an awful lot of insight in regards to the 2.5L motor and gave me several garrett and borg warner options to look into.
Originally Posted by FullBlown,Dec 7 2010, 07:58 PM
Ive gotten a chance to tune both turbos. The 5857 turbo spools about 200 rpm before a 6262 ,but you will be limited with higher boost. The 6262 is a perfect turbo for the s2k. The problem is that the s2k motor is so efficient that when you run a small turbo or housing, it really chokes the motor up top. You have a built 2.5L , that is why I would stick a 6265 or a 6262 on it.
I have also had experience with Mase's kit and too me there was not a big difference between the 6262 or 5857 either using the same center section and A/R.
In fact I could see no big advantage with ball bearing turbos either. If I ever do another it will be journal bearing, the reliability is arguably better depending on the application and use.
Really it is the entire package that makes the turbo though, turbine A/R makes a huge difference in spool, compressor A/R is also worth noting, intercooler and system surge volume, turbine wheel design, manifold design..........
Differences between the standard Garret Style exhaust turbine and Greddy. I not found any reference yet but I have been told that the new Borg Warner turbos have VERY light and efficient turbine wheel now.
Sorry to dig up an old thread guys, but at this point I'm leaning towards picking up a GT30/5857 sized turbo for the car.
At the end of the day, I want the spool and midrange characteristics of the smaller turbo, and really don't plan on upping the power beyond 400whp.
With that in mind, is the GT30 the turbo to go with. Most of what I've read indicate it's a more reliable turbo than the 5857. Would you recommend I go with the .63 AR or .82 AR? I'm thinking that the .82 is probably the best option, but I'm not 100% sure.
Is there any reason why my stroked motor would respond differently to the smaller turbo?
